ffmpeg import from DVD - glitchy audio (SOLVED)
progcode
Re: ffmpeg import from DVD - glitchy audio
Post by progcode » Wed Mar 21, 2012 11:20 pm
steve wrote:
kozikowski wrote:
Do the VOB files play correctly in other applications (for example in VLC)?
That's what I want to know. This smacks strongly of a damaged disk. Koz
Or a copyright protected disk that has foiled the ripping software.
Thank you all for taking the time to try to help with this. As it turns out, the VOB files do not play correctly in VLC. They glitch in the same way. I didn't realize I was just dealing with a difficult disc. Other discs produce better importing results. So instead of being able to import this audio directly, I have to play the disc and use audacity to record the live Windows stereo mix. More of a pain, but at least now I can proceed. Thanks again.
Re: ffmpeg import from DVD - glitchy audio (SOLVED)
Post by steve » Thu Mar 22, 2012 1:19 am
Topic marked as solved.
