Audacity and DJM900nexus problems with record mix
Hello guys.
I have problem with record my mix from my DJM900 nxs1 with Audacity by USB cable. I have HP i7 with Win 10 x64. I did connection via DJM900 app , aso setup all in Audacity, recording working, but on my mix still are a lot crash. Like my mix be recording from old vinyls…
Maybe you have some advice what check , to eliminate this a ot crash.
Thanks
You don’t say what version of Audacity you are running… Several users have reported issues with their DJM900, but this is the first “crashing” report I recall. Are you running the most recent Pioneer drivers?
You can check for related forum posts by searching for “DJM900” in the upper right-hand corner of this page.
