My playback recordings are coming out in a ‘Darth Vader-ish’ voice and I can’t find the fix. I’m using an ATR2100x mic. I’ve tried some minor things like unplugging the mic from my laptop then plugging it back in, and adjusting the Gain, but nothing has solved the problem.
DVDdoug,
Is that in ‘Settings’?
Here’s a direct link to the relevant part of the manual: Why do my recordings fade out or sound as if they were made in a tunnel?
Sorry… I didn’t double-check my link.
