How to remove breath noise without affecting Noise Floor
Hi everyone. I’ve noticed that using noise reduction for breath removal has a negative affect on floor noise. Hence when I use the ACX check I sometimes run into an issue where I fail. The work around is to go through the file and find each breath but that takes a while. Any suggestions? Thanks in advance.
There’s an app for that … https://forum.audacityteam.org/search.php?keywords=Waves+de-breath
Wow. Thank you!!!
Don’t part with money until you can get it to work, (there is a demo version).
You’ll need the latest version of Audacity to use VST3 plug-ins.
