This automatic download of 3.2 is causing me lots of headaches and extra work to do anything … things like delete, cut and paste. etc…
Is there a way to go back to my other version … and if so, can I somehow just muddle along with that one and not have any future ‘automatic’ downloads. I’m 3/4 way through a book for ACX but I’m stymied how to proceed using the new version.
If I’m stuck with 3.2 is there a good tutorial?
Thanx, Tom
Thanx, I’ve figured out most of it but after I recorded the new chapter, my RMS is too high. For instance, the ACX Check shows:
Peak -3.7 pass
RMS -28.2 fail
Noise -68.5 pass
The RMS is bad and I need to adjust it but don’t know how anymore … used to have an effect for that. I also used to use a Hum Removal effect but can’t find that either
Sooooo, I’m stuck with the RMS issue … can you bail me out???
