[SOLVED] Invalid tocken in line 410 error
Hi all,
Few days ago I started creating a project in Audacity 1.3.14 Beta. I realised it’s very old version so I installed 3.2.0 version (separate application). The problem is, that I can’t open the file in both versions, because of following error message: “not well-formed (invalid tocken) in row 410”. I’m 100% sure, that file was saved correctly, without any crashes etc. I found solution that it can be opened in notepad and I need to delete corrupted row, but to be honest I can’t do it on my own. Not enough skills even to find this row…
Can anyone help me with this issue? It’s very important for me, I have to finish this task this weekend. Many thanks in advance!
Topic can be closed, I’ve solved it, sorry
