Hi! Can you help me, please?
How to use Nanokontrol2 in Audacity?
You cannot do this. Audacity does not work with these DAW controllers, nor does it do USB-Midi. From the Korg site: Specifications | nanoKONTROL2 - SLIM-LINE USB CONTROLLER | KORG (USA),
it appears to be compatible with Avid Pro Tools, Apple Logic, Apple GarageBand, MOTU Digital Performer, Steinberg Cubase, Ableton Live, and Cakewalk SONAR.
If you are looking for a mixer-style control for Audacity, try View > Mixer.
While that is true, there’s possibly a (rather complicated) workaround, which is to use a 3rd party app to translate MIDI controller messages into simulated key presses. Much of Audacity accessible from keyboard commands. An app that may be able to do this is:
Bome MIDI Translator. (Disclaimer: I’m guessing as I’ve never used Bome MIDI Translator)
Thank you very much for the information and suggestion, I will work Thanks
