VST / VST3 Presets Format and 3.2.0 beta
I’m using the TDR Nova Plugin.
While testing the Audacity 3.2 beta i noticed that the VST-version saves presets as xml and the new realtime VST3-version saves them as “.vstpreset”, which means i can’t just import my old presets into the new version.
Is there a way to convert xml to the new format so i can keep using my presets?
Didn’t want to post this in the 3.2. beta feedback thread since i’m not sure it counts as a bug…?
