Hi, is there any way to see the list of all clips in a audio track?
Hi, is there any way to see the list of all clips in a audio track and clicking a clip’s name from the list will take me to the clip region in the track? Just like we can do in edit lebels option. Please help me asap, very urgent. Thank you.
Please help me.
Audacity does not have that feature. Clip names is a fairly new feature, and it doesn’t do anything other than allow you to attach a name to a clip. The documentation is here: Audio Clips - Audacity Manual
Perhaps if you describe why you need it, there may be an alternative approach.
Tyvm for replying. i want it so that i could easily navigate to a specific clip of a very long auidio file which consists many many named clips.
Clip names is a recently added feature, and currently it does nothing more than display text at the top of a clip. Clip names are not supported by Audacity’s “scripting”, and there are no tools in Audacity for working with clip names.
The only workaround that I can think of is to use labels instead of clip names.
