Playback
I’m trying to record a podcast with 2 usb mics on my windows 11. I have installed Voicemeeter and Audacity. It appears to be recording without issue. When I want to playback the recording, I can only get it to playback in one mic. I’d rather have it playback either in both mics?
Thanks!
An addendum. I’m using 3.1.0 Audacity
Yes - that is correct. Audacity is only going to output to one device at a time.
If you need it in both mics that is going to be between you and Voicemeeter.
Thank you for the response!
