Is there some automatic way in Audacity to reduce damages done to music due to loudness war? Or in some other Windows software?
I do not expect it to be perfect- but to just ease / speed up process of further manual reversing of this loudness insanity, which is pseudo-dynamics and clipping. You know: to make a [typical] modern released recording sound more like it was released in the 1980s
I am using Audacity 2.4.2 [but if needed I can upgrade] on Windows 10 Enterprise 20H2 19042.746 x64
You MIGHT be able to improve the sound but you can’t really reverse the damage…
Sometimes compression is reversable if you know all of the settings/parameters. In the analog days DBX noise reduction used “compansion” and I believe it was also used in analog telephone systems. The signal is compressed before recording (or transmission) and expanded during playback (or receiving). That greatly improves the signal-to-noise ratio and dynamic range. It was never popular because unlike Dolby noise reduction it sounded terrible when played-back without decoding. And of course, digital made it obsolete.
But with music production there are several issues (besides the unknown settings/parameters)… With limiting (and clipping) it’s impossible to know the original height or shape of the waveform. Sometimes multiband compression is used (with more unknown parameters). Often compression is used on the individual tracks before mixing so that’s impossible to reverse if you only have the final mix.
…And, I suspect that much of it is in the performance, arrangement, and playing style. We’ve got a couple of generations of musicians & producers who think music is supposed to be constant-loudness. …We can’t have any quiet parts or any louder drum-hits or cymbal crashes, or anything that stands-out from the background!
