[SOLEVED]Recording starts fine, then is muffled.
Hi everyone.
I’m using Windows 10 (unfortunately) and Audacity 3.1.3, and every time I start recording, it records fine for a few seconds then muffles the rest, and won’t act right unless I restart it. It does the same thing every time I restart.
How can I fix this?
Make sure [u]Windows “Enhancements”[/u] are turned off.
What are you recording?
This worked, thanks!
