Is there any way to find out chords/transkribe from songs in Audacity?
Nothing that is included in the Audacity package. Are you familiar with chordify ?
The track spectrogram view can enable you to see note frequencies (particularly using the “Pitch EAC” algorithm and “Period” scale - see: https://manual.audacityteam.org/man/spectrogram_view.html)
There’s a page here that shows frequencies for note names so that you can look up the note names for the frequencies that you see in the spectrogram: https://pages.mtu.edu/~suits/notefreqs.html
Then you need a little music theory to work out the cords from the notes (https://www.bbc.co.uk/bitesize/guides/z8tsh39/revision/1)
