I would like to create a stereo track that is 1 second long consisting of a 95 Hz click train. I would like the individual clicks to consist of a 1000 Hz tone that lasts for 50 ms (10 ms rise and 40 ms fall time).
I can generate a tone, but don’t know how to specify the rise & fall time.
Once I generate the single click/tone, how do I get it to repeat 95 times per second? The “repeat” function under the Effect menu just loops the file, but doesn’t constrain it to 1 second in length. I want to create a file that inserts the clicks/tones evenly throughout the 1 second interval to create a 95 Hz click/tone train.
Any suggestions would be truly appreciated!
(In case you’re curious why I want to do this, the file will be used as a stimulus for an auditory entrainment EEG paradigm in a psychology experiment)
Thanks!
AwesomeEEG
Do you mean that you want the “clicks” to occur 95 times per second?
That would mean that the start of each click would occur each 1/95 seconds = 10.53 ms. (approx)
So each “click” overlaps its neighbour by 39.47 ms?
