CHANGING PITCH
When I change pitch it sounds horrible!
Can somebody tell me how to fix this?
Thnx
Large pitch changes will always sound unnatural.
Try both with and without “Use high quality stretching (slow)” selected. Depending on the audio that you are processing, one may sound better than the other.
If the tempo is not important, try the “Change Speed” effect instead of “Change Pitch”.
Thanx 4 your advice
