[SOLVED] TL_TimeMachine failed to load libraries (Windows 10)
Hi, so I have been trying to use the TimeMachine plugin. I tried looking on YouTube, and used the 32bit VST, but it didn’t work.
I’m currently using Audacity 3.1.3, build ff6d67 if that helps.
If anyone here can give me a working fix, I would really appreciate it. It’s pissing me off.
Open “Help menu > About Audacity” and look in the “Build Information” tab. Does the “Build type” say 32-bit or 64-bit?
If you mean ToneBoosters (TB) Time Machine plugin, there’s now a free 64-bit version.
It says 64 bit.
Then you need to use 64-bit plug-ins.
32-bit VST effects will not work in 64-bit Audacity.
Thanks, I’ll try and see if it works.
It worked, thank you!
