Is there any way to turn off the loud ding when you get a warning / popup? I wear a headset while editing and the ding is extremely loud compared to the audio that I am editing.
Turn down the master volume on your computer.
Audacity’s volume slider used to do this, but now it only controls Audacity’s volume, and not system sounds such as “dings”, so now you have to control the master volume using the Windows sound controls. (I now set Audacity’s volume control to maximum and leave it there, and use the system volume control instead).
