Auddacity 3.0 and plus
Is it possible to add in the new versions of Audacity to work with the .aup files? Most of the software allows to open and edit old files made with old versions, except Audacity.
Thank you.
Audacity 3.x does support importing the old “AUP + _data” project format.
Only AUP3 is supported for saving projects.
