Hi,
I’ve locally compiled a Windows 64 bit version of Audacity 3.1.3 to include ASIO support. Everything’s working fine, but I’m missing the ‘Application’ menu choice from the Edit → Preferences menu, which would enable me to automatically check for updates (newly introduced feature with 3.x.x, I believe). This menu option should be immediately below the ‘Modules’ menu choice per documentation (see https://manual.audacityteam.org/man/application_preferences.html) ; see screen shot:
Anyone else seeing this? Suggestions for fixing? Is this perhaps a consequence of local compilation vs downloaded build?
Thanks,
John
