Compression Driver Harmonics
Hi! I have been trying to recreate the harmonic response of compression drivers.
Basically I have a square tone, the higher in frequency the louder even harmonics are generated.
This should also work with voices/etc as it sounds like rectifier distortion.
I am trying to recreate the harmonic response heard from this video: https://www.youtube.com/watch?v=WC-XG6UsIwo
Could anyone help me?
The siren has odd & even harmonics …
https ://manual.audacityteam.org/man/spectrogram_view.html
https://manual.audacityteam.org/man/plot_spectrum.html
Yes it does, I am trying to match the even harmonics on my square wave.
I didn’t watch the video but the [u]Distortion Effect[/u] has several options (including odd & even harmonics) and there is an optional [u]Harmonic Enhancer Plug-in[/u].
I’ll try experimenting again with the distortion plugin.
Thanks for your responses!
