Can't Find FFmpeg_v2.2.2...exe
Hi,
I’m following the instructions at:
file:///C:/Program%20Files%20(x86)/audacity/help/manual/man/installing_ffmpeg_for_windows.html
Step 3 in the instructions reference the exe…
However when I go to the download site:
https://lame.buanzo.org/ffmpeg64audacity.php
The installer exe is there but not the file referenced in step 3:
FFmpeg_v2.2.2_for_Audacity_on_Windows_64bit(1).exe
I’ve tried the manual process with the zip file but can’t find the library, so would be great if I could follow the original (non zip) instructions.
Any help would be appreciated,
Paul V
I have a related question (won’t repeat here) but I think that wiki is outdated as Audacity 3.1.x per release notes is supposed to allow more recent versions of ffmpeg libraries to be used.
scott s.
I agree - the instructions seem to be incorrect. On my machine, after first checking with Windows Defender that there was no virus, I double-clicked on “FFmpeg_v2.2.2_for_Audacity_on_Windows_64bit.exe” (no need for ‘(1)’) which then took me to step 4, and the following steps went smoothly.
So Peter, if you are listening, change step 3 from
Left-click FFmpeg_v2.2.2_for_Audacity_on_Windows_64bit(1).exe to launch the installer…
to
Double-click FFmpeg_v2.2.2_for_Audacity_on_Windows_64bit.exe to launch the installer…
(I need to stay out of the virus discussions. :wink: )
I’ve made that correction in the alpha-manual. (The release manual cannot be edited),
Thanks, Steve. If you could also change the “Left-click” to “Double-Click” that would be good. :wink:
Thanks All,
I’ll give that a try.
