Corrupt AU3 (blockfiles) and ballooning filesize?
Hey all,
In a bit of a bind here with a large project I was editing. I foolishly saved and closed the project before exporting a .wav of both tracks, and now when I try to open the .aup3 file I receive this error:
“timestamp”: 1642187027,
“event_id”: “e03ab02581f0d54b914b971b4d812092”,
“platform”: “native”,
“release”: “audacity@3.1.3”,
“contexts”: {
“os”: {
“type”: “os”,
“name”: “Windows”,
“version”: “10.0.22000”
“exception”: {
“values”: [
“type”: “Error_Opening_Project”,
“value”: “Project is corrupt\n(Unable to work with the blockfiles)”,
“mechanism”: {
“type”: “runtime_error”,
“handled”: false,
“data”: {
“sqlite3.query”: “DELETE FROM sampleblocks WHERE NOT inset(blockid);”,
“sqlite3.rc”: “11”,
“sqlite3.context”: “ProjectGileIO::GetBlob”,
“log”: “(Unable to work with the blockfiles)\n11:03:47: Loaded 83 string Kb in size\n11:03:47: sqlite3 message: (11) database corruption at line 66843 of [1b256d97b5]\n11:03:47: sqlite3 message: (11) database corruption at line 66993 of [1b256d97b5]\n11:03:47: sqlite3 message: (11) statement aborts at 8: [DELETE FROM sampleblocks WHERE NOT inset(blockid);] database disk image is malformed\n11:03:47: DBConnection SetDBError\n\tErrorCode: 11\n\tLastError: Project is corrupt\n(Unable to work with the blockfiles)\n\tLibraryError: database disk image is malformed\n”
I immediately ran a chkdsk on the drive this project is on, but it came up clean. I also noticed that the project file itself was now roughly 25GB (!) which seems hugely inflated, even though it was a very long project.
Is there anything I can do? If I could even just extract my recording, that would be extremely helpful.
This size may pose a problem.
See if you can’t zip up the file and post it on a public file sharing service. If not, try again with winrar.
Post (or PM me) a link and I’ll take a look at the project.
What’s very long?
Audacity works internally at 32-bit floating format, and yes, that can be significantly larger than the same material at audio CD file standard (16-bit). It will be massively worse if you started with MP3 or other compressed files.
There is a caution about those. If you use MP3 or other compressed files in a show, you can’t make a new MP3 without the sound quality getting worse. MP3 format is a time bomb.
You should have WAVs of all original work, all the raw recordings, interviews, etc.
The up side is that’s the last time you make that mistake.
Thanks a ton! I’ll compress it and see where the best place to upload is, then shoot you a PM.
The project is about 3 hours and 40 minutes currently. It didn’t start from MP3, and for reference similar projects that clocked in at roughly the same time have uncorrupted .AUP3 files sitting around 2-4GB, which is what makes me think 25GB is an outlier.
I know, I know. Normally exporting the raw files as .wav is the first thing I do, but in this case life happened and I had to leave to go take care of something else and had forgotten by the time I came back. This is the first time I’ve had a project file corrupt on me like this; in other similar situations the old project file structure held up just fine. It is what it is!
Looks like I can’t send PMs yet, so here’s a link to a zipped file. Thanks a ton for taking a look at this! I’d be happy to reimburse you as thanks for your time/data. If it saves any time, the only thing I actually need is the top track as I do have an export of the bottom track.
Assuming we can recover the file, I’ll likely do this to save both space and time. Downloading now… :smiley:
Lovely! Thanks so much again for taking a look.
So the rescued file wasn’t much smaller that your original file so, as you suggested, I deleted all the tracks but the first and the file size came down dramatically! I have uploaded this trimmed file and PM’d you the link. :smiley:
Thank you so, so much! You’re a hero. :smiley:
:blush: (blush!) You’re welcome. :smiley:
