Chrls
December 7, 2021, 2:56am
1
Hi community,
Trying to keep it short:
UAD Apollo Twin X @ 192khz, 512 Buffer, Clock:Internal
Windows Speaker & Windows Mic @ 32bit 192khz
Audacity @32bit 192khz Wasapi (Latency 100ms standard settings)
OS: Windows 11
Audacity Version: latest
Recording is destroyed and sounds like: https://1drv.ms/u/s!AubrBNqET6WngsNcw1PAAF_gwBnajw
What can I do?
Asio in FLSTUDIO works well. But i need it via wasapi.
Chrls
December 8, 2021, 3:49pm
2
Do you need further information from my side?
Can I assist somewhere?
Regards
December 8, 2021, 5:05pm
3
Why do you need WASAPI rather than MME?
Why do you need 192 kHz rather than the default 44.1?
Chrls
December 9, 2021, 12:19pm
4
I need Wasapi to be able to record next to Qobuz playing at 192kHz. When the interface is set to this resolution the Input must be at 192kHz too.
I could find a bypass solution in the meantime.
The issue is that Apollo does not support 32bit if I understood correctly.
So as Windows lets me only select 32bit it destroys the stream and audacity gets a damaged stream.
So far it’s all fine with Audacity.
Have a good one,
Chris
