I’m using Audacity 3.1.3
Windows 11 Home version 21H2
I encountered an error while exporting a prerecorded radio show which combined music tracks (mp3) and voice recording in mono on a Scarlet Focusrite and a Shure PGA27 mic. I encountered an error while exporting and when I attempted to reopen the file, I get the following messages.
When attempting to open the original file, I get this.
Project is corrupt. Unable to work with the blockfiles.
“timestamp”: 1638814930,
“event_id”: “f41f550255fe1d4a86842246b1322495”,
“platform”: “native”,
“release”: “audacity@3.1.3”,
“contexts”: {
“os”: {
“type”: “os”,
“name”: “Windows”,
“version”: “10.0.22000”
“exception”: {
“values”: [
“type”: “Error_Opening_Project”,
“value”: “Project is corrupt\n(Unable to work with the blockfiles)”,
“mechanism”: {
“type”: “runtime_error”,
“handled”: false,
“data”: {
“sqlite3.query”: “DELETE FROM sampleblocks WHERE NOT inset(blockid);”,
“sqlite3.rc”: “11”,
“sqlite3.context”: “ProjectGileIO::GetBlob”,
“log”: “13:22:05: Error: Failed to load shared library ‘’ (error 126: The specified module could not be found.)\n13:22:05: Error: Failed to load (error 126: The specified module could not be found.)\n13:22:10: Loaded 168 string Kb in size\n13:22:10: sqlite3 message: (11) database corruption at line 71416 of [1b256d97b5]\n13:22:10: sqlite3 message: (11) statement aborts at 8: [DELETE FROM sampleblocks WHERE NOT inset(blockid);] database disk image is malformed\n13:22:10: DBConnection SetDBError\n\tErrorCode: 11\n\tLastError: Project is corrupt\n(Unable to work with the blockfiles)\n\tLibraryError: database disk image is malformed\n”
When I attempt to open a duplicate backup of the file, I got a message that it was "Unable to parse project information, and the following error code.
“timestamp”: 1638815027,
“event_id”: “a2a1591aef062a4098b923d305e1b7d1”,
“contexts”: {
“os”: {
“type”: “os”,
“name”: “Windows”,
“exception”: {
“values”: [
“mechanism”: {
“handled”: false,
“data”: {
“sqlite3.rc”: “11”,
“log”: “13:23:46: Error: Failed to load shared library ‘’ (error 126: The specified module could not be found.)\n13:23:46: Error: Failed to load (error 126: The specified module could not be found.)\n13:23:46: Loaded 168 string Kb in size\n13:23:46: sqlite3 message: (11) database corruption at line 71416 of [1b256d97b5]\n13:23:46: sqlite3 message: (11) statement aborts at 8: [DELETE FROM sampleblocks WHERE NOT inset(blockid);] database disk image is malformed\n13:23:46: DBConnection SetDBError\n\tErrorCode: 11\n\tLastError: Project is corrupt\n(Unable to work with the blockfiles)\n\tLibraryError: database disk image is malformed\n”
I’m hoping the file is rescuable and that someone can help.
