Hi, I am storing my mp3 recordings out on google drive to share with my choir mates. I get an error when i try to open the mp3. I copyed the files to other cloud sharing software and it works great.
Any ideas how to work around this?
Thanks!
-D
Thanks!
-D
Could just be Audacity being fussy about the type of mp3, (rather than file corruption)
I have a few of the exact same mp3s stored out on different cloud platforms, namely dropbox, and onedrive. The file loads on both of those platforms - audacity shows it is importing the mp3 and just plays it.
If its on a Google drive, i get that error msg. I will try with some different file types to see if there is a difference…
I wonder if you get the same error if you start Audacity first, then open your .mp3 file.
Good idea! Gave it a shot - same error. Im using 3.0.2 - I’ll try upgrading…
