Is it possible to remove this (below) which was introduced in the new update? I searched the whole settings section but found nothing. I need the both sides to look identical, or it looks like one side is louder.
Also the dragging tool is gone…
The bar at the top is the new “drag bar” (referred to in the manual as “Clip Handle”), and it replaces the old Time Shift Tool.
The “Clip Handle” is a new, permanent feature of audio clips, which is described by the new head of design as “much faster and more intuitive” than using the old drag / move tool.
The name of the clip can be edited or deleted by double clicking on it and then typing.
So, no way to change it back then? I guess I’ll use the older version then. Thanks for the answer.
I just updated to A 3.1 and can not find the time shift tool or how to use a substitute. One entry in this thread said use the Drag bar.
What is that and where is it located?
Thanks!
I found my answer - please ignore my request for help in using the clip movement feature, which is in fact much easier to use than the old time tool.
