is audacity ver 2.1.3 backwards compatible with ver 2.1.2?
All the version 2 Audacity programs are sisters of each other. Why do you need to know this?
Yes, but both are obsolete.
Why would I need to know this???
I would need to know if I should remove the newer version and go back to the older verson.
So far I have the newer version working in Win7 at a setting of 125 for buffer size and -150 for Latency.
I checked the XP Drive and it has the same settings for buffers and latency.
You are asking me a question about anything?
Either yoiu don’t care or you are just asking because you really don’t understand.
