Import Difficulty with Version 1.2.6 Project
When originally created, the Project.aup file and Project_Data folder (with all the .au files) were both on c:\ (root directory). With Win 10 using Version 3, you cannot put them in the root so I created c:\audacity and put them there. Then Open Project.aup works but “stacks” all tracks on top of each other. Would appreciate your help with this.
Maybe that’s what the project was like when you saved it.
What is the project and what do you want to do with it?
Also, does Tracks > Align Tracks > Align End to End help ?
