Constant bitrate on wav file?
Exotery
Post by Exotery » Thu Jun 24, 2021 1:35 pm
where can I set a constant bitrate for a .wav (RIFF WAVE) file in Audacity? Heeelp plz :) thank you
DVDdoug
Forum Crew
Re: Constant bitrate on wav file?
Post by DVDdoug » Thu Jun 24, 2021 1:56 pm
What are you trying to do?
The bitrate of a regular uncompressed WAV/RIFF file is always constant.
For example, a "CD quality" WAV file is 16-bits x 44.1K samples per second x 2 channels = a bitrate of 1411 kbps (kilobits per second).
Exotery
Post by Exotery » Fri Jun 25, 2021 1:22 pm
oh that helps me alot thank you :)
