Know the amplitude (volume) of a file.
Marcos
Post by Marcos » Sat Jun 19, 2021 5:17 pm
Hello everyone!
I would like to know if there is any way to know or measure the exact amplitude (volume) of a file? Reason why I intend to leave all my video-lessons with the same volume.
Thank you very much!
Re: Know the amplitude (volume) of a file.
Post by steve » Sat Jun 19, 2021 6:24 pm
1. Select the audio that you want to measure (it could be the entire track, or just part of a track)
2. Open the "Amplify" effect.
3. Observe the default "Amplification (dB)" setting.
By default, the Amplify effect offers to amplify up to 0 dB, so the "Amplification (dB)" setting shows the number of dB required to make the selection up to 0 dB. Put another way, it shows the number of dB below full track height.
4. Click the "Cancel" button to close the Amplify effect.
Example: If the peak amplitude of the selected audio is -20 dB, then the Amplify effect will offer to amplify by +20 dB. Thus, if the default "Amplification (dB)" says "20", then we know that the peak amplitude of the selection is -20 dB.
Marcos
Post by Marcos » Mon Jun 21, 2021 2:37 pm
Hi Steve!
First I ask you to please consider my faults regarding the duplicity of the topic, it was my distraction.
Regarding your example, get this straight: If the peak amplitude of the selected audio is at -20dB, the Amplify effect will offer and present +20dB amplification. In this example, can we conclude that the audio (-20) is too low and needs to be applied (+20) to be normalized to the 0 (zero) standard?
Not to open another topic, on one occasion I met a puglin that makes the audio uniform (single volume) mainly the voice. Could you let me know what this puglin would be so I can download it?
Thank you very much friend!
Post by steve » Mon Jun 21, 2021 2:44 pm
Do you mean that it made loud voices quieter and quiet voices louder?
If so, that may have been the Nyquist plug-in: "Level Speech" which you can get here: https://wiki.audacityteam.org/wiki/Nyqu ... vel_Speech
Instructions for installing Nyquist plug-ins: https://manual.audacityteam.org/man/ins ... st_install
