I have a Casio WK-210 keyboard and a Windows 10 PC, both of which are connected via a USB adapter.
I was hoping to record and edit music from the keyboard by using Audacity on my PC, but I can’t figure out how to record.
Can anyone help?
I need help recording with Audacity- Windows 10
Isabel5184
Re: I need help recording with Audacity- Windows 10
Does it show-up as a Recording Device?
The USB connector on that keyboard is for exchanging MIDI data with a computer or other MIDI devices. It is not an audio output for recording sounds.
If your computer has a LINE IN jack, you could connect the keyboard's headphone output to it if you get a cable with the correct plugs, probably 1/4 inch stereo plug to 1/8 inch stereo plug.
As DVDdoug has alluded to and as jeffm has been saying, in a word, NO.Isabel5184 wrote: ↑Thu Jun 17, 2021 11:13 amI have a Casio WK-210 keyboard and a Windows 10 PC, both of which are connected via a USB adapter.
Can anyone help?
Audacity has LIMITED MIDI support. It does NOT CURRENTLY support direct MIDI recording over USB. You CAN do this with other software packages, for example, Cakewalk and/or Reaper may be able to do this.
You CAN record the audio (e.g. headphone) output from the Casio if you get a third party USB adapter, such as the Behringer UFO202,UCA202, or UCA222.
Oh, I stand corrected. Which USB adapter are you using? Or are you just talking about a USB cable?
Isabel5184
Yes!!!DVDdoug wrote: ↑Thu Jun 17, 2021 1:34 pmDoes it show-up as a [Advertising removed] Recording Device?
