how to remove/filter out unwanted audio noise using audacity
Re: how to remove/filter out unwanted audio noise using audacity
Post by steve » Tue Jun 15, 2021 9:59 am
ShirleyGuzman wrote:
Tue Jun 15, 2021 9:39 am
I do have a short audio file
If the file is no more that about 10 seconds long, you can attach it to your reply so that we can evaluate the issue.
See here for how to attach a file to a forum post: viewtopic.php?f=49&t=64936
