Cannot Export or Save As Project
NSRWebMonkey
Post by NSRWebMonkey » Mon Jun 14, 2021 10:24 am
Hi, I've been working with Audacity to edit podcasts for several years now, and just upgraded to 3.0.2. While working on the most recent one, I finished the edit, and tried to export. When the progress bar was a third of the way through, the export failed with the error message, "Audacity failed to read a file on drive F:." When I tried to save the project as a different file name, I got this error message:
My questions are:
1. What's gone wrong?
2. Is this recoverable or am I utterly screwed?
The project file opens and plays back in Audacity without issue, as far as I can tell without sitting through all 62 minutes of it.
Re: Cannot Export or Save As Project
Post by steve » Mon Jun 14, 2021 12:02 pm
Try saving to your "Documents" folder. Does that work?
