3.0.2 Windows 10
I have dozens of cassette tapes (ct) I need to transfer to a different format. Likely wav or MP3 to make CD. After trying three brands of "convertors" that transfer ct to a USB drive and the devices failing to transfer to the USB (interestingly all were exactly the same with different name plates) I obtained one that transfers directly to the computer. It comes with a mini-CD which loads Audacity 2.1.3 and the appropriate LAME. It is rumored that the software will not run under Windows 10. I have computers still running Windows 7 and I can use one of those if need be.
My question is, can I directly load the ct output into Audacity 3.0.2? Which input settings on Audacity will I need to use. I do not want to add an outdated Audacity to my Windows 10 computer.
Audio Capture From Cassette Tape
chatgroslegrande
Re: Audio Capture From Cassette Tape
For making audio CDs, best to export your recordings as standard (16-bit stereo, 44100 Hz) WAV files. Audacity uses these settings by default when you select "File menu > Export > Export as WAV".chatgroslegrande wrote: ↑Sun Jun 13, 2021 8:08 pmI have dozens of cassette tapes (ct) I need to transfer to a different format. Likely wav or MP3 to make CD.
Some CD players can also play "MP3 CDs", which are "data CDs" containing MP3 files. You can get more MP3 tracks on a data CD than you can audio tracks on an "audio CD", but many CD players cannot play data CDs.
For compatibility with most CD players, you must select "audio CD" as the CD format in your CD burning software.
One of these type of things?chatgroslegrande wrote: ↑Sun Jun 13, 2021 8:08 pmI obtained one that transfers directly to the computer.
If so, they are easy to use when they work, but have a terrible reputation for not lasting very long before becoming a paperweight. Keep your receipt.
They also tend to come with obsolete versions of Audacity.
So long as the device actually works, then yes it will work with any version of Audacity.chatgroslegrande wrote: ↑Sun Jun 13, 2021 8:08 pmMy question is, can I directly load the ct output into Audacity 3.0.2?
We no longer support Windows 7 (it became officially obsolete last year), but if you want to use Audacity on a Windows 7 machine, then Audacity 2.4.2 is probably your best option. You can get it here: https://www.fosshub.com/Audacity-old.html
Note that with the update from Audacity 2.x to Audacity 3.x, the project format changed. Audacity 3.x can open projects created with Audacity 2.x, but the old 2.x cannot open projects created with the new 3.x.
If you are only going to use Audacity on the Windows 10 machine, then I'd recommend Audacity 3.0.2 (the current version) which is available from the main Audacity website: https://www.audacityteam.org/download/
We're hoping to release Audacity 3.0.3 soon, so keep an eye out for that - it will have some important bug fixes.
If you intend to use Windows 7 and Windows 10, then I'd recommend the older Audacity 2.4.2, but consider retiring your Windows 7 machines soon
There's a collection of detailed tutorials about transferring cassette / vinyl to CD here: https://manual.audacityteam.org/man/tut ... to_cd.htmlchatgroslegrande wrote: ↑Sun Jun 13, 2021 8:08 pmWhich input settings on Audacity will I need to use.
