Hi,
I'm using Audacity 2.4.2, but I can upgrade to the latest if needed. I also have Windows 10.
I'm attaching a link to a voice sample from a Skype call: https://mega.nz/file/ExtgjDqY#perJYLgYY ... -b4E9BWY_A
Any way to reduce noise from this? I already took out some fuzz, ambient noise and such. Any way to clean this up? The noise only happens during talking and not during pauses.
Thanks.
Reducing Noise from Skype Call?
monkeywisdom
Re: Reducing Noise from Skype Call?
I don't think it is possible to make significant improvements to the audio quality of that recording.
Who recorded the call?I'm attaching a link to a voice sample from a Skype call:
