Hi, I Cannot import mp4 file because the ffmpeg fails.
I used to be able to do this no problems, and then… not.
I have tried many things to no avail, and now ask for help from those who know!
Error Message:
“[file name]” is an advanced audio coding file. Without opening the optional ffmpeg library, Audacity cannot open this type of file. Otherwise, convert it… etc.
The same thing happens for other mp4 files.
I have downloaded the FFmpeg files multiple times, locating them manually through edit-preferences-libraries.
No matter where the FFmpeg files are, the same message comes up.
I am using Windows 10 Home
I have updated to Audacity 3.0.2
mediainfo info:
Complete name : X:\HDD audio\bkp\tubers\Climate crisis\An Inconvenient Truth.mp4.mp4
Format : MPEG-4
Format profile : Base Media
Codec ID : isom (isom/iso2/avc1/mp41)
File size : 294 MiB
IsTruncated : Yes
Audacity log (this one is opening the file from the folder using “open with”. I cant open it from Audacity either.)
20:42:32: Audacity 3.0.2
20:42:32: Trying to load FFmpeg libraries...
20:42:32: mLibAVFormatPath ('X:\HDD audio\bkp\btl\editing tracking\doc pack for editors\ffmpeg-win-2.2.2\avformat-55.dll') is not empty. Loading from it.
20:42:32: Looking up PATH environment variable...
20:42:32: PATH = 'C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\WINDOWS\System32\WindowsPowerShell\v1.0\;C:\Users\Scotty\AppData\Local\Microsoft\WindowsApps;'
20:42:32: Temporarily prepending ';X:\HDD audio\bkp\btl\editing tracking\doc pack for editors\ffmpeg-win-2.2.2' to PATH...
20:42:32: Checking for monolithic avformat from 'X:\HDD audio\bkp\btl\editing tracking\doc pack for editors\ffmpeg-win-2.2.2\avformat-55.dll'.
20:42:32: Error: Couldn't find symbol 'avutil_version' in a dynamic library (error 127: The specified procedure could not be found.)
20:42:32: Error: Couldn't find symbol 'avcodec_version' in a dynamic library (error 127: The specified procedure could not be found.)
20:42:32: avformat not monolithic
20:42:32: Loading avutil from 'avutil-52.dll'.
20:42:32: Loading avcodec from 'avcodec-55.dll'.
20:42:32: Loading avformat from 'X:\HDD audio\bkp\btl\editing tracking\doc pack for editors\ffmpeg-win-2.2.2\avformat-55.dll'.
20:42:32: Actual avutil path X:\HDD audio\bkp\btl\editing tracking\doc pack for editors\ffmpeg-win-2.2.2\avutil-52.dll
20:42:32: Actual avcodec path X:\HDD audio\bkp\btl\editing tracking\doc pack for editors\ffmpeg-win-2.2.2\avcodec-55.dll
20:42:32: Actual avformat path X:\HDD audio\bkp\btl\editing tracking\doc pack for editors\ffmpeg-win-2.2.2\avformat-55.dll
20:42:32: Importing symbols...
20:42:32: All symbols loaded successfully. Initializing the library.
20:42:32: Retrieving FFmpeg library version numbers:
20:42:32: AVCodec version 0x373466 - 55.52.102 (built against 0x373466 - 55.52.102)
20:42:32: AVFormat version 0x372164 - 55.33.100 (built against 0x372164 - 55.33.100)
20:42:32: AVUtil version 0x344264 - 52.66.100 (built against 0x344264 - 52.66.100)
20:42:32: Returning PATH to previous setting: C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\WINDOWS\System32\WindowsPowerShell\v1.0\;C:\Users\Scotty\AppData\Local\Microsoft\WindowsApps;
20:42:32: FFmpeg libraries loaded successfully.
20:42:32: File name is C:\Users\Scotty\dwhelper\Dr. Christine Jones - Building New Topsoil Through The Liqui.mp4
20:42:32: Mime type is *
20:42:32: Opening with libav
20:42:32: Opening with legacyaup
20:42:32: Opening with libsndfile
20:42:32: Opening with liboggvorbis
20:42:32: Opening with libflac
20:42:32: Opening with libmad
20:42:32: Opening with lof
20:42:32: Error: Importer::Import: Opening failed.
20:56:20: File name is X:\HDD audio\bkp\tubers\soils and farming\Christine Jones\Dr. Christine Jones - Building New Topsoil Through The Liqui.mp4
20:56:20: Mime type is *
20:56:20: Opening with libav
20:56:20: Opening with legacyaup
20:56:20: Opening with libsndfile
20:56:20: Opening with liboggvorbis
20:56:20: Opening with libflac
20:56:20: Opening with libmad
20:56:20: Opening with lof
20:56:20: Error: Importer::Import: Opening failed.
Appreciate any help you can give!
