recording controling volume recording from utube
pop's
Post by pop's » Fri May 28, 2021 2:41 pm
I'm new to this and learning. How do you control the recording volume from utube to audacity to keep playback from clipping?
DVDdoug
Forum Crew
Re: recording controling volume recording from utube
Post by DVDdoug » Fri May 28, 2021 4:48 pm
If you are using WASAPI loopback you should be "capturing" the digital audio stream and it shouldn't clip unless the original YouTube stream is clipped, and there's nothing you can do about that.
