Hi,
I'm trying to time stretch a midi, is that possible in current version? If so, how do I do? Can't find any info about this in the manual.
This is not necessary information for the question, but I'm trying to replicate this process (they're using Reaper in this video): https://www.youtube.com/watch?v=N4MUaX664xY
Kind regards,
Astro
Version:
3.0.2, win 10
Midi stretch
Re: Midi stretch
Audacity's MIDI capabilities are very limited, but you can change the tempo of a MIDI track by using a "Time Track". See: https://manual.audacityteam.org/man/time_tracks.html
If you're wanting to much with MIDI, you would probably be better to use a different app, such as Muse Score or Reaper.
