Why is my audacity slow
jessicamxox
Post by jessicamxox » Thu May 27, 2021 5:23 pm
this has been going on for a while let me explain so I usually use tempo a lot when making my videos and recently every time I want to change the tempo it takes hours to finish loading to the range I wanted it in and recently I tried everything with downloading again and with trying to see if it was my wifi it cant be my wifi I recently got it fixed and I had people waiting for me to actually post and do their requests and its piling please help have to do my work. Thank you.
Re: Why is my audacity slow
Post by steve » Fri May 28, 2021 6:05 am
Do mean: "I usually use the Change Tempo effect a lot"?
Do you mean that the "Change Tempo" effect takes a long time to process the selected audio?
If so:
How long is the selected audio?
Is the "Use high quality stretching (slow)" option enabled?
