Noise Reduction: Unable to correct Validation Error Message [SOLVED]
MechEng
Post by MechEng » Wed May 26, 2021 2:15 pm
OS: Windows 10
Mic: Procaster
Audio Interface: Focusrite Scarlett
Audacity Ver: 3.0.2
I have just updated from 2.4.2 to 3.0.2 and have identified an issue with the Noise Reduction effect.
I am going through the normal procedure of selecting a small sample of audio at the start of my track, selecting Noise Reduction and Get Noise Profile.
I then get an error message:
'Value Not in Range 0 to 24'
I have made no changes to my recording process. I am recording directly into Audacity.
I have tried altering the noise reduction and sensitivity settings to no avail. I have even tried re-installing and have read all I can on the Forum and Wiki.
This is something i have not experienced before on the earlier version of Audacity and would greatly appreciate some help as I have a lot to edit in the next few days.
Thank You
Helen
Re: Noise Reduction: Unable to correct Validation Error Message
Post by steve » Wed May 26, 2021 2:43 pm
Ensure that "Sensitivity" is set between 1 and 24. The default value (recommended) is 6.
Default settings are: 12, 6, 3, reduce=selected.
See: https://manual.audacityteam.org/man/noi ... ction.html
MechEng
Post by MechEng » Wed May 26, 2021 4:15 pm
thanks for the quick response Steve,
yes, I have been using the default settings, with
NR = 12
S = 6
FS = 3
this makes no difference.
Is it possible there is a bug in the noise profile generator?
Has anyone else noticed this problem?
is there a workaround, such as using a low-pass filter instead?
Post by steve » Wed May 26, 2021 4:24 pm
What language are you using?
Have you modified the Windows setting for number formats (decimal separator)?
MechEng
Post by MechEng » Wed May 26, 2021 5:46 pm
have it set to english. (am in the UK)
have not made any alterations to number formats - not sure i know how - but I will find out and check.
MechEng
Post by MechEng » Wed May 26, 2021 5:59 pm
Hi Steve,
Youre a STAR! :ugeek:
Im set to english (am in the UK)
Found my way into the regional number settings, and looks like it was set to European, with full-stops for decimals.
have re-started Audacity and it looks like its now working.
Thank you for the help, i was relly getting worried I wouldnt finish my project.
regards
Helen
Re: Noise Reduction: Unable to correct Validation Error Message [SOLVED]
Post by steve » Wed May 26, 2021 6:36 pm
You're welcome.
I'll close this topic as "solved".
