Error -9999 cant record -_-
rinmaila
Post by rinmaila » Sat May 22, 2021 9:04 pm
Hello
i cannnnnnot record to to error ( - 9999_
i use Toshiba laptop
Windows 10
Blue Yeti Pro Studio.
please help... life is tooo hard without audacity -_-
jademan
Forum Crew
Re: Error -9999 cant record -_-
Post by jademan » Mon May 24, 2021 1:34 am
Check Frequently Asked Questions (FAQ)
Do you have windows permission to use the microphone ?
Also, try entering 9999 in the search box in the upper right-hand corner of this page.
