Macros are not exporting the files in the Audacity 3.0.2 windows 10
acxeditors
Post by acxeditors » Fri May 14, 2021 6:06 am
Hi There,
in the previous versions of the audacity, after applying macros the audacity use to create a new folder "macro-output" and save all the files automatically to it. But now macros are working fine BUT they aren't exporting the audios. e.g, I created a macro of which steps are 1) Normalizing, 2) Noise reduction, 3) Limiter, and finally 4) Export. it is performing all the 3 steps but is not exporting the final file nor creating a new folder "macro-output". So, I export all the files manually.
Any Help would be much appreciated.
Thanks
Nauman(ACX Editors)
waxcylinder
Re: Macros are not exporting the files in the Audacity 3.0.2 windows 10
Post by waxcylinder » Fri May 14, 2021 7:22 am
The export location was changed for Audacity 3.0.2
See the What's New.... page in the 3.0.2 Manual: https://manual.audacityteam.org/man/new ... tml#output
The default location on Windows is: C:\Users\<your username>\Documents\Audacity
You can change that to a location of your choice in Directories Preferences.
Peter.
acxeditors
Post by acxeditors » Fri May 14, 2021 11:07 am
Hi Peter.
Thank you very much for your prompt response. Does this mean that now audacity will not create a new folder "macro-output" automatically in the same folder(where the files are already present)?
Thanks again and have a great day.
Nauman
Post by steve » Fri May 14, 2021 11:17 am
Audacity will create the "macro-output" folder in the Macro output directory. You can specify where you want the Macro output directory to be in Preferences, as shown here: https://manual.audacityteam.org/man/new ... tml#output
It does not create a "macro-output" folder in the same folder as the input files, unless that happens to be your chosen Macro output location.
acxeditors
Post by acxeditors » Sun May 16, 2021 9:41 am
Thank you very much, Steve.
By the way, this was a great feature(creating the folder automatically in the same directory where the files are) but, thank you for your kind help.
Post by steve » Sun May 16, 2021 1:33 pm
I'm hoping that behaviour will be restored as an option in a future version of Audacity, but in the meantime, there's a Nyquist plug-in available here that can be added at the start of a macro to automatically set the output folder to the same location as the imported file: viewtopic.php?p=422865#p422865
Instructions for installing and enabling Nyquist plug-ins on Windows: https://manual.audacityteam.org/man/ins ... st_install
