I am using 3.0.2 on a Windows 10 laptop.
It worked properly when I first ran it. But now, audio playback will route audio output to my connected HDMI monitor, even though my PC audio settings have the built-in speakers as the default playback device.
I can't find any setting in Audacity to route where audio output goes. Is this problem just a setting up issue?
Playback is piped to HDMI monitor when PC settings is on speakers
Re: Playback is piped to HDMI monitor when PC settings is on speakers
Ensure that you have the appropriate playback device selected in the Device Toolbar.
