Am using Windows 10 v20H2 build 19042.928 and Audacity 2.4.2
Is there any way to make Audacity open THD+AC3 files directly?
(one way is to convert THD+AC3 to FLAC using eac3to, as Audacity opens FLAC files)
When Audacity is asked to save an 8-ch audio file to AC3 (which normally handles only 6-ch), it simply discards the extra 2 channels or lets you assign them manually. What is the correct way to downmix 8-ch audio to 6-ch AC3?
TIA
Request for Audacity to Open THD+AC3
SoundFiend
- Operating System: Windows XP
Re: Request for Audacity to Open THD+AC3
This sort of thing is difficult for open source software as there is a very real risk of falling foul of patent laws.SoundFiend wrote: ↑Sun May 09, 2021 5:47 amIs there any way to make Audacity open THD+AC3 files directly?
TrueHD is patented by Dolby.
Last time I looked, FFmpeg had an experimental, reverse engineered TrueHD codec. I don't know what the current status of that codec is, and given that it may infringe on Dolby's patents it may not be enabled in the FFmpeg library that you are using.
If you have a TrueHD encoder that works, then perhaps you could export as 8 channel WAV or 8 channel FLAC and then use your encoder to create an 8 channel TrueHD AC3.SoundFiend wrote: ↑Sun May 09, 2021 5:47 amWhen Audacity is asked to save an 8-ch audio file to AC3 (which normally handles only 6-ch), it simply discards the extra 2 channels or lets you assign them manually. What is the correct way to downmix 8-ch audio to 6-ch AC3?
