I have a Dell Inspiron running Windows 10.
I am trying to record a stereo signal out of a Behringer QX1002USB mixer into Audacity (3.0.2) using the USB connection. I have a stereo signal at the mixer, but when recording, Audacity seems to 'double' the left hand channel to create the stereo recording. The right channel from the mix is lost.
I have also tried going from RCA line outs of the mixer through a Behringer UCA222 interface. There is a stereo signal at the interface, but again Audacity records a 'double' of the left-hand channel only. The right channel is lost.
I have also tried taking a stereo signal via RCA from a tape deck through the UCA222 interface. Same thing happens. Stereo signal at the interface but Audacity record a 'double' of the left-hand channel only.
I have tried combinations of MME, Windows DIRECT SOUND and Windows WASAPI with all devices in the drop-down but have the same issue.
Is this a driver issue?
Any suggestions gratefully received.
Thank you
Kevin Demmon
Records half of stereo signal
Re: Records half of stereo signal
Make sure Windows is set-up for stereo. There is some information here.
See ... https://youtu.be/59QY0WL3f64?t=17Pastiche wrote: ↑Sat May 08, 2021 11:25 amI am trying to record a stereo signal out of a Behringer QX1002USB mixer into Audacity (3.0.2) using the USB connection. I have a stereo signal at the mixer, but when recording, Audacity seems to 'double' the left hand channel to create the stereo recording. The right channel from the mix is lost ...
