MP3 Render Missing Tracks But It Gets Weirder...
feraldrollery
Post by feraldrollery » Sat May 08, 2021 12:26 am
5 Tracks, mixed down, levels ok, playback sounds OK, but then I rendered it and Bluetoothed the mp3 to my phone. Through my phone speakers there are missing track 4. And it's not even faint or ambiguous. But the weird part is that you can hear it just fine through the headphones. Hmmm, maybe I have a left or right channel out on my phone speakers? But I've been experiencing all kinds of issues with my levels. Anyway, maybe you could shed some light on it. Thanks!
Re: MP3 Render Missing Tracks But It Gets Weirder...
Post by kozikowski » Sat May 08, 2021 12:53 am
Can you trace where you got track 4 from?
I'm putting serious bets that the Left and Right of Track 4 are out of phase. Can you get track 4 on a timeline by itself? Tracks > Mix > Mix Stereo down to Mono. I bet it vanishes. Normal songs don't.
Does it? If it does, you can fix this song. Edit > UNDO and back out to the original stereo song. Menu on the left > Split Stereo Track. Select one of the two tracks > Effect > Invert.
Select the top track > Menu on the left > Make Stereo Track. Now make your sound file and I bet it works just fine.
It is super-duper important to know where you got that track from. It's possible you have a sound system that is damaging music files—and you have a lot of these.
This isn't a newbie problem. There was a recent National Public Radio interview where the interviewer's microphone was out of phase and she vanished when you listened to the show on a phone, but not on the radio.
Post by steve » Sat May 08, 2021 5:17 pm
Was track 4 a stereo track? If so, then I think kozikowski's diagnosis is very likely to be the answer.
feraldrollery
Post by feraldrollery » Sat May 08, 2021 9:50 pm
Sorry, spaced it...
*Windows 10
feraldrollery
Post by feraldrollery » Sat May 08, 2021 10:03 pm
Track originated from a sampling audio app on my phone. It's an absolute turd of a phone, as well. ZTE.
BTW, would you/could you remark on another issue while we're here, so I don't have to start a new thread. I appreciate it immensely!
Multiple tracks, imported from FL Studio Mobile. Then I went to record some bass an vocals live. Waveforms of imported files look good, no peaks. I had to really crank up my live recording tracks (amped ALMOST to peaking), bring down my FL beats almost -20db, but the live tracks were still coming through very faintly. Different results between monitor speakers and headphones.
I was also wrestling with levels similarly in Reaper. I suspect this OP render/level issue is related. Feeling like a total noob over here. Thank you for your patience!
Post by kozikowski » Sun May 09, 2021 12:22 am
I think you're the poster child for stereo phase problems.
https://www.kozco.com/tech/LRMonoPhase4.mp3
Here's a 40 second sound test in four parts. Left, Right, Mono, and intentionally phase damaged.
Listen to this on your speakers and headphones. All four parts should be about the same volume. The last part may sound a little weird, but should not drop in volume. I think there's zero chance you'll make it through the whole test.
feraldrollery
Post by feraldrollery » Sun May 09, 2021 2:11 am
Aye!! The phase part went blargly on my phone.
I do have this habit of playing around with phase/inversion. I get a mad kick out of that "in the room" sound. Back to the drawing board.
Post by kozikowski » Sun May 09, 2021 2:28 am
Busted...
