Cursor Not Snapping To Some Labels from Beat Finder
dmelorj
Post by dmelorj » Fri May 07, 2021 2:55 pm
Hello,
I'm using Windows 10 and Audacity 3.0.0
I've noticed that moving cursor near some labels that were created with Beat Finder do not create that yellow line that snaps the cursor to the bondary of the label.
At some label it works and some don't.
I've recorded a short video to demonstrate this behavour.
https://www.youtube.com/watch?v=q42XNomCtUY
Re: Cursor Not Snapping To Some Labels from Beat Finder
Post by steve » Fri May 07, 2021 4:31 pm
You need to turn off "Snap To" (set it to "None").
See: https://manual.audacityteam.org/man/sel ... olbar.html
dmelorj
Post by dmelorj » Mon Jun 14, 2021 5:51 pm
Steve, thank you! It worked like a charm.
