I have two downloaded files, an .exe and a .zip
When opening either one, I get the ‘permissions’ error attached, even as Admin.
Any suggestions appreciated.
When trying to attach screenshot, I get error:“File too large” !!? (It’s only a small scrsht saved in .rtf doc)
– but here’s what it says:
C:\USERS..[path to ] …3.0.2.exe
Windows cannot access the specified device, path, or file. You may not have the appropriate
permissions to access the item.
Ensure that you are logged into your computer with your normal user account.
Move the Audacity installer EXE to your desktop, then double click on it to run it.
You should be prompted to give permission for the installation. Depending on how your PC is set up you may be prompted to enter your password (whatever is “normal” when you install an app).
I’m not sure what else to suggest. So far you have given us part of an error message that says that you do not have appropriate permissions.
Perhaps it will help if you give us a step by step description of exactly what you are doing, and exactly what happens.
(unrelated) I’m noticing that your replies are inserted Before my last post instead of at the bottom, and I’m not noticing that they’re there; also the email notices stopped. …?..
any idea why I couldn’t add a small screenshot on that original post?
I’ll start over and explain in as much detail as I can –
Give me a few minutes
