EmvoiceOne plugin not recognized
Immortality
Post by Immortality » Sat Apr 24, 2021 5:35 pm
Hello everyone,
Thank you for hosting this forum.
I run Windows 10, with Audacity 3.0.0.0
I have searched the FAQ, the Internet, and this forum for my specific problem. Please forgive me, should my question already have been treated. I am new to music editing, and all the new terminology can overwhelm me a bit, especially in the face of some rather substantial documentation.
I'm trying to install a voice synthesizing plugin called Emvoice (https://emvoiceapp.com/). They say they should be compatible with Audacity, but Audacity does not recognize the plugin after I have run the Emvoice setup. I tried to see if there are any .ny files in the Emvoice installation folder that might needed to be moved to the Audacity plugin folder, but no luck there.
I came across the term VST. This seems to be a type of software that intermediates between the myriad types of plugins and the myriad audio editing applications. On searching the Internet for this, I merely found costly "plugin bundles". This seems to imply that my understanding that VST is an intermediating piece of software is wrong. This means I am truly clueless as how to install Emvoice, and would really appreciate some help here. Again, I apologize should this be a common question already answered, answers that my neophyte eyes obviously could not recognize.
Thank you and yours kindly,
Immortality
Re: EmvoiceOne plugin not recognized
Post by steve » Sat Apr 24, 2021 6:11 pm
Audacity does not support VST or AU instruments, so I doubt that it will work in Audacity.
I'd suggest that you ask them how to use it with Audacity.
Trebor
Post by Trebor » Sat Apr 24, 2021 7:07 pm
emvoice do explicitly mention Audacity ...
emvoicd- audacity.png (73.25 KiB) Viewed 82 times
They do offer a 32-bit version, but no joy in Audacity in Windows ...
It's gotta be a VSTi, that would exclude Audcaity.
jademan
Forum Crew
Post by jademan » Sun Apr 25, 2021 7:19 pm
