Maybe try a different theme to make the highlighted part more obvious ...
https://manual.audacityteam.org/man/themes.html
Selected part of a track not highlighted
Re: Selected part of a track not highlighted
We can't tell if it's selected or not while you are using a custom theme. Try the default "Light" theme.
How exactly are you doing that?archismanghosh wrote: ↑Tue Apr 20, 2021 5:43 pmwhenever I'm selecting a portion of an imported track
waxcylinder
You don't have a selection in the track waveform - you have a time range selection in the Timeline.archismanghosh wrote: ↑Wed Apr 21, 2021 2:20 pm@Trebor, I tried doing that but no use. The selected part is simply not getting highlighted!Check the screenshots in the below Google drive, for reference...
https://drive.google.com/drive/folders/ ... sp=sharing
This just defines a time range for Quick Play
See: https://manual.audacityteam.org/man/timeline.html#usage
You need to click & drag in the waveform to make an audio selection.
And see: https://manual.audacityteam.org/man/aud ... ction.html
